1998 Johnson 130. I removed lower unit. I changed the whole water pump. When I put it all back together I noticed there is a VERY SLIGHT gap between the plastic housing and the metal plate. I removed it and did it again. All the bolts are tight and the large o-ring is in place. The gap is right in the middle between the bolts. And when I say gap I mean its MAYBE the size of the thickness of paper. Is it ok? Or does it need to sit absolutely tight to the metal plate?
