Need help with serial ID 0C116573
Stevo90
I have a 25hp 2 stroke Mercury engine that found a boulder in the river, I would like to fix it, but it needs a new lower gear case.
I am unsure which models are interchangeable, any help would be greatly appreciated
Thanks,
MERCURY 25 EL ( 25 H.P. (1989) Serial No: 0C116573 Model No: 1025312GD
Parts catalog, http://www.marineengine.com/parts/mercury_marine_parts/sn/0C116573 or,
http://www.boats.net/parts/search/MercuryMarine/0C116573/367/parts.html
In this list of lower gear cases below, you'll need to find the color & length to match yours, then click on the part number and you can look at a long list of engine models the part number will fit on.;)
http://www.boats.net/parts/search/M.../190/Gear Housing(Propeller Shaft)/parts.html
Hope this helps, Good luck.:)
Thank you!
It's really shocking that there aren't more used motors in my area that's interchangeable. I may end up buying a new case.
Then a jackplate shortly thereafter haha
