I think papyson is probably right on target. I do not know if your helm or hull is metal, but if the shifter, if mounted in the dash, does not have the proper size cutout, it is very easy for the 12v lead going to the trim button to short against the helm as it goes through the shifter mounting and the cutout. That will pop the fuse right now!
I would go ahead and do wiggle tests etc, but you should contact the dealer who installed it for them to check out. This is a safety issue.
As long as you have not modified their wiring (like tapping into the wiring for power for electronics, etc) it should covered under warranty.
Mike
