What is your location ???-------Very important detail !
I have a sport jet V-6 block that needs rebore on all 6.----Plastic drive gear failed on the oil pump.---If you can not find a good used block that may be an option for you.------Located in southern Ontario.--------What is the part # that is cast on the block ( not the number from a parts book ) so I can check to see if it is the same.
