starcraftnate
To make a long story short i have a 99 islander with a 4.3 mercruiser. Unfortunantly i have been blessed with the single piece exhaust manifold/riser. The boat has never seen salt water in its life. The pump in the outdrive is good. The thermostat is working. One riser is cold (port) and i burt my hand on the other (starbord). I took the hot manifold off and had it smoke tested. The (auto) mechanic said he plugged the three exhaust ports and the center on the outlet. I was not there to witness, but was told smoke came out the water drain plug. Would a cracked riser cause enough pressure to stop the flow of water through that side? I am willing to buy the 2 piece conversion, but would like to see if anyone else has encountered the same issue.
Any advice/help much appreciated
