whitegreg56
It's a 1998. I've noticed that the control lever (the part that the timing link connects to) doesn't come near the maximum-timing-adjustment screw when the engine is put in forward and W.O.T. (the engine is not running). It stops shy.....might move a little more from engine vibration (if the engine were running). The engine runs fine and the adjustment screw has NEVER been changed. I see the same thing on other 8HP 2-stroke Mercury. So, what's the point in trying to set the maximum spark advance to 36 degrees BTDC, if the engine timing never gets that far?? Is this something that only applies to the 9.9HP or 15HP models??
