Results 1 to 2 of 2
  1. #1
    Default Fireball 140 head pull
    I have a 1947 Correct Craft with the original Fireball 140. I'm pretty sure it has a blown head gasket. I'm going to pull the head and wonder what precautions I should take or things I should worry about. I read in the manual to loosen the head studs slightly and use the starter and turn the motor over slightly to break the seal on the head without breaking it. That manual is the original 1947 manual and just making sure that is still the recommended procedure. Another concern I have is the tachometer. Should I take it off or leave it on? I want to make sure I don't break that component. Any help appreciated.
  2. #2
    Join Date
    Feb 2010
    Location
    McHenry, Illinois, USA
    Posts
    71
    Default Re: Fireball 140 head pull
    Remove the tach drive and spark plug wires. Also remove the temperature sender wire if equipped. Remove anything else connected to the cylinder head. Remove all the nuts and try to lift the head without prying between the block and head. Object is not to disturb the head gasket so you can tell if it is bad and get the number off it for a replacement.
Similar Threads
  1. help please, pull the head off 7.4 MPI
    By vinceFR in forum Mercruiser Sterndrive Forum
    Last Post: 05-04-2010, 12:21 PM
  2. Mariner 28 hp pull start wont pull
    By azza01 in forum Mercury Mariner Outboard Archive
    Last Post: 07-10-2007, 06:00 PM
  3. Pull start wonbt pull
    By brigan in forum Archive 2003-2007
    Last Post: 09-13-2006, 10:30 PM
  4. Pull start wonbt pull
    By brigan in forum Mercury Mariner Outboard Archive
    Last Post: 08-03-2006, 01:51 AM
  5. Pull start on 92 Envinrude 8hp Wonbt Pull
    By Pete camelo in forum Johnson Evinrude Outboard Archive
    Last Post: 05-03-2004, 02:31 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
