I'm in the middle of one of these right now. I just picked up the water pump rebuild kit for my buddy's 86 Force 125. It took a mercury Quicsilver part number FK1069 from marine engine.com for $99.91. Yours is probably the same. I unbolted the lower gear case. There was one hidden bolt at the exhaust port. I also had to disconnect skinny little shift linkage rod. It then came apart easily. There you will find the at the bottom of the shaft. I was told to coat the impeller and housing with a little vasoline to to prevent burning also always have water on when running. Piece of cake. Good luck!
