whitegreg56
I have an old NS3.5A that starts and runs beautifully. I've found that if I start it at idle, it won't pump any water for as much as 30 seconds. I shut it down at that point. There is what appears to be exhaust coming out of the rubber outlet hose at start-up. If I open the throttle, it does start to pump but not much. I have replaced the impeller and head gasket (metal rim). Ran a wire into the water outlet. Checked the seal at the base of the water tube. The water tube itself appears to be OK (at least the bottom). I cleaned all the salt and sand out of the water jacket around the cylinder. I'm running out of ideas!! Has anyone seen this?? The season is fast approaching.....
