Results 1 to 16 of 16
  1. #1
    Default Prop won't spin in forward or reverse
    89 evinrude 200hp v6 .On the way back to the launch I noticed a knock or a click of some type. So I stopped and put her in neutral to listen to just the motor, no knock or click heard. So I put her in forward and she bogged down when I accelerated (just had the carbs rebuilt) so I cranked her back up. Put her in gear and just sorta slow rolled her. Hearing the knock or click again so I assumed it was something in the foot. I gave her a bit of gas and then BAM! I felt something give and a lot of vibration so I immediately took her out of gear and cut the engin off and trolled back. I got her out of the water, I see no oil around the foot, but when I put her in gear the prop will not spin in either direction for forward or reverse. What has happend and pleaser tell me it's not the worst case scenario
  2. #2
    Join Date
    Apr 2006
    Location
    , Langkawi, Malaysia
    Posts
    5,750
    Default Re: Prop won't spin in forward or reverse
    Draining the gear oil will probably give you an indication.
  3. #3
    So drain the gear oil
  4. #4
    Does it spin in neutral? There would definitely be something wrong if it did spin in gear when not running. I suspect you'll find the problem on the end of the oil drain screw ...
  5. #5
    It wil spin freely in neutral . But in gear no budge
  6. #6
    Join Date
    May 2010
    Location
    Sebastian ,Fl
    Posts
    2,417
    Sounds like it's gonna be expensive?? Take the prop off and remove the bearing carrier. that will tell all. Oh yea drain the oil first.
    88 Bayliner with 2002 225 HP Mercury EFI
    Buy American made Cars and Trucks!!!Towing insurance for a boat,a GREAT thing.
    ​Tools to make my life easier: Battery tester, die grinder, temp.gun, compression tester, DVA meter.
    In Scenic , Beautiful San Sebastian by the sea Florida
  7. #7
    I'm taking it to my boat guy today to get him to look at it, will post what the conclusion is later, also in the drain oil am I looking for metal shavings?
  8. #8
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,142
    Likely chunks of metal on the magnet.
  9. #9
    Join Date
    Apr 2006
    Location
    Posts
    5,750
    Or worse, a broken crank shaft (due to the vibration). Did the water pump work?
  10. #10
    Yes the water pump was brand new! I dropped the boat off. I will know later today what the damage is. If anyone has a lower unit laying around for it would be great! When I know the damage I will let you guys decide wether or not I should find a lower unit or if I should get the work done.
  11. #11
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    SEI new lower unit w/3 year warranty.
    Fix minor things (replace wear items for preventative maintenance.) that cause major problems before they break.
  12. #12
    Yes one guy quoted me 1600 for All of it?
  13. #13
    No 1600 for a SeI lower unit
  14. #14
    Got the estimate. $800 for a used lower unit completely overhauled.
    He said the whole foot is locked up, gears are stripped and he can't get the v clip off . He said it is tore up Bad going to look. He said the problem had to of been going on for quite sometime but it finally have out
  15. #15
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    Sounds fair to me if it includes a reseal.
  16. #16
    Yes he said he was going to completely service the used one, new seals, water pump!
Similar Threads
  1. Johnson 9.9 spin prop maybe?
    By gfinch1050 in forum Johnson Evinrude Outboard Forum
    Last Post: 06-27-2011, 08:25 AM
  2. Prop does not spin
    By tbird72503 in forum Mercury Mariner Outboard Forum
    Last Post: 03-29-2010, 09:10 PM
  3. Prop want spin under a load
    By jeremy27 in forum Mercruiser Sterndrive Archive
    Last Post: 07-06-2009, 12:37 AM
  4. Replies: 2
    Last Post: 09-13-2006, 10:59 PM
  5. Merc 402 prop neutral spin
    By Brent Dambergs in forum Mercury Mariner Outboard Archive
    Last Post: 12-31-1969, 08:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
