Sooner5151
is there any negs. to pulling off my manual fuel pump and replacing it with an electric one? Thanks for any advice about this switch.
I like this idea, but how would one plumb in the pump if leaving the mechanical pump?There's an alternate to the start-by-pass, if interested.
That would be a helm located momentary switch in lieu of the start-by-pass circuit. This allows for fuel pump operation prior to any engine cranking. Push a botton or move a toggle switch, and you have fuel pump operation.
The benefits are: no unnecessary cranking prior to fuel delivery, no unnecessary battery drain, and to some degree, this will even extend starter motor life!
Most who end up going to the electric fuel pump, remove the mechanical, and block the opening off. Some mounting kits even use the mechanical pump bolt pattern.
If in series, does fuel flow freely through these electric pumps when not in use?
I believe that these are rotary vane type pumps, and may not flow as with the mechanical pumps.
I've not tried this, so I really can't answer that!
it would have to for that to work.
If in series, and if the electric pump was the "ride along" pump, then yes, it would need to be!
But again, I don't know whether one would free flow or not.
Or would I run this pump parallel to the mechanical pump?
Again, by the time that the electric pump is considered, the mechanical pump is ready to be abandoned.
If the latter, I assume I would need two check valves (or 1 shuttle valve) to resolve the positive output from either pump to the carb. so the pump in use doesn't push backwards through the one not in use (path of least resistance), or maybe my anti siphon at the tank would ensure that doesn't happen.
I have lots of shuttle valves for hydraulics, but doubt they are fuel approved.
If we get into valving, we also get into areas that may not conform to USCG regs.
These regs (regarding gasoline) can be rather complicated and long drawn out. I've read them before, and you have to dig rather deep for certain criteria.
I'm sure that you could find it..... but be ready for a long read.
I bought this boat used and it is a 1981 Formula F18 with a 305 chev engine. I rebuilt the carb and found water in the fuel bowl area of the carb and the jets were corded up, I can imagine what the fuel pump looks like. I want to replace it before ice off and fishing starts. The external fuel bowl on the fuel pump is empty but you can see it has been there a long time. Just thought I would be proactive instead of reactive and not need to be towed to back to the dock. I fish mainly by myself.
yes, I do have the canister filter. I pulled the castiron exhaust off and am cleaning them up due to my budget says I will have to use them at least another year. Got any good ideas for the gasket for the caps and 90degs turn downs. I will also need to replace one of the water hoses due to I had to cut it off. The hoses were stuck on pretty hard. Thank you.
