Click for Crusader parts and manuals!
Results 1 to 8 of 8
  1. #1
    Join Date
    Jan 2008
    Location
    peterborough, ontario, canada
    Posts
    14
    Default Borg Warner v-drive output shaft seal leaking
    Was told that the seal leaks due to incorrect alignment of the shaft, causing side pressure on the seal. Has anyone run into this before??
  2. #2
    Join Date
    Aug 2008
    Location
    Fairport, NY
    Posts
    1,672
    Default Re: Borg Warner v-drive output shaft seal leaking
    If the seal failed due to side loading, the bearing failed first.
  3. #3
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    4,868
    Agreed.
    Is the boat in the water or on the hard? When did it start leaking?
    Chris
    Dockside Marine Services
    Jersey Shore.
    Mercruiser/Mercury Certified
    Let the insanity begin.
  4. #4
    Join Date
    Jan 2008
    Location
    Posts
    14
    boat is on the hard for the winter. started leaking mid summer last year. I have no vibration or noise. just the leak. want to make sure i get it fixed right the first try. you are saying the seal has failed due to the out put shaft bearing failing? would there not be some other sign of this?
  5. #5
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,260
    Depends upon how the seal failed...
    If the bearings wore out because of misalignment the seal won't work.
    I've seen a few seals fail from corrosion...not common but possible....also seen them fail due to poor workmanship during rebuilds...
    Irregardless, with a V-drive, you want to get it correct before you launch her...check locally and make sure you find a shop/mechanic with a stellar reputation...
  6. #6
    Join Date
    Jun 2009
    Location
    Belleville, Ontario, Canada
    Posts
    15
    As has been said, you can't side load a seal without a lot of slop being present in the bearing. Vibration from an misaligned shaft is kind of hard on seals, but you said you don't feel any vibration while underway. These seals do wear out. They are a simple pressed in oil seal, no big deal..... but you need to pull the tranny, and replace the reduction gear gaskets on the way by. Frankly, if you're going to do the rear seal, do the forward seal and all the gaskets too. You have it out anyway, and the basic gasket seal kit is cheap.
  7. #7
    Join Date
    Jan 2008
    Location
    Posts
    14
    Hoping to get to uncover boat next weekend and start to disassemble for inspection. Plan is to disconnect shaft from coupling and slide it out of the road. Will check torque on coupling nut. Have seen in the automotive application the nut come lose and cause problems. Should be able to check for play in coupler at that time which should indicate wear in the bearing? Remove coupling and inspect for groves or burn marks. What are the chances of the coupling coming off with ease? 1987 searay. Looks like there is room to remove bearing cap to replace seal on the bench. If no signs of any other problems,reassemble with new seal,silicone on shaft before nut and check shaft alignment once boat is back in water. Any other advice would be good as I don't want to have to do this twice.
  8. #8
    Join Date
    Jun 2009
    Location
    Posts
    15
    I am not really familiar with that new a borg, but the older paragon v drives used a pressed in seal, and a whittet-higgins nut on the end of the coupling, but there are various types of nuts. For the most part, these seals are oil seals and do not want any other contamination on the seal. nice clean shaft through the seal, with a little bit of the transmission fluid smeared on it during assembly.
Similar Threads
  1. Borg Warner Velvet Drive has play in drive
    By rwerner43 in forum Miscellaneous marine engine topics
    Last Post: 06-03-2011, 01:30 PM
  2. Borg Warner Velvet Drive Lay Up
    By coaster in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 05-10-2009, 05:32 PM
  3. Replace InputOutput oil seal on borg warner 71c Velvet Drive
    By searay57 in forum Crusader Marine Archive
    Last Post: 02-28-2008, 08:09 PM
  4. Leaking seal on borg warner velvet drive
    By Jack Top in forum Crusader Marine Archive
    Last Post: 07-21-2007, 04:14 PM
  5. Replacing Rear Oil Seal Borg Warner Velvet drive
    By senzbar in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 10-29-2006, 06:58 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
