I have water in the lower unit do I need to replace all prop shaft seals or just the outer one can i replace it or them with out taking apart the lower unit do i need special tools to do so i will be replacing the water pump also should i replace upper drive shaft seal while it is apart and do i need special tools for that.
thanks
thanks
