You didn't post a year but...
True, but he did give us this....
4.3l v6 OMC Cobra stern drive ..... which suggests an approx year range from 1987 to 1993.
During those years, the OMC 4.3L points style ignition systems would have been very similar.
Could you be more specific about the wobbling? is it as simple as pulling the cap off the distributer and grab the shaft that the rotor button spins on? if it wobbles then remove and replace it?
thanks,
Myles, the lower shaft bushing typically wears before the upper bushing due to the cam drive at this location. Neither is good.
A worn bushing no longer holds the correct tolerances, and if this was to become excessive, it can cause shaft wobble.
Excessive shaft wobble may create a vibration, premature drive/driven gear wear, and may throw the dwell off on either points style or electronix triggering.
As said in the other thread, usually by the time we're considering an electronic conversion, the existing distributor is old and worn.
In your case, having been powered in 2002, you may be OK.
Just pull the distributor, and examine the bushings. If you're considering changing to Electronic, you'd be re-setting the ignition timing anyway.
- should i clean the points again and make sure that everything is tickity-boo?
- or would it be better to change out to electronic ignition?
- is there a benefit?
- loss?
- perks?
1... No.... replace them and set the correct dwell, not gap!
2... Need more info.
Do you mean as in a completely new electronic style ignition distributor......, or as in a Pertronix conversion kit to your existing???
3... As per my previous post: "you'll likely not see a big performance increase, but you will see better start-ups."
(with the assumption that your contact point system is working correctly to begin with)
4... None, other than installing the ESA Contact Points-to-Electronic Ignition "module" that allows the ESA to work with the electronic triggering.
5... No more contact points!
Keep in mind how important the correct progressive advance curve, and TA (total advance), are regarding top performance.
The best of the best electronic triggering won't solve an incorrect or malfunctioning progressive advancing issue.
