Results 1 to 9 of 9
Thread: Stuck Flywheel
  1. #1
    Join Date
    Jun 2011
    Location
    Ontario Canada
    Posts
    107
    Default Stuck Flywheel
    1972 40hp Johnson. Flywheel is stuck. Really stuck. broke a grade 8 bolt while pulling. Tried hitting puller center with 2 lb hammer while under tension. Tried heat from propane torch. Tried penetrating oil. Using a 1/2" air impact gun on puller.
    I encountered one like this a year ago. 1970 40 hp Johnson. Eventually the puller pulled the flywheel off, but in the process left the entire center section of the flywheel still stuck to the crank shaft taper. Essentially the puller tore the flywheel apart. Had to saw off the remainder.
    I really don't want a repeat of that mess. Any suggestions on what to try when flywheel removal goes really, really bad?
    Thank you.
  2. #2
    Join Date
    Jun 2011
    Location
    Ontario Canada
    Posts
    107
    Default Re: Stuck Flywheel
    Thanks for the advice. I will try the power steering fluid.
  3. #3
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    4,785
    Tighten up the puller and hit it really hard. Harder than you are currently hitting it.
    Chris
    Dockside Marine Services
    Jersey Shore.
    Mercruiser/Mercury Certified
    Let the insanity begin.
  4. #4
    Join Date
    Apr 2006
    Location
    , Langkawi, Malaysia
    Posts
    5,750
    Power Steering Fluid is just another 'name' for ATF. Main difference is the ability to absorb/tolerate water.
    To make it aoll work quicker:
    Attach the puller and tighten down.
    Heat up the flywheel with a propane torch close to the center.
    Take a can of Freeze Spray and spray the crank shaft tap!!!
    This will make the tap 'shrink' and makes it easier for the ATF to penetrate down.
    Repeat several times if needed.
  5. #5
    Join Date
    Jun 2011
    Location
    Ontario Canada
    Posts
    107
    How hard to hit is hard to describe. I am using a 2 pound iron mallet. I am beyond tapping at it. I would call it a medium hit. You think I should go near full on? I am afraid of damaging bearings or fracturing the carbon seal.
  6. #6
    Join Date
    Jun 2011
    Location
    Ontario Canada
    Posts
    107
    Freeze spray, that is a great idea! Thanks for all the ideas Gentlemen. Will report back in a day or two.
    How hard can you hit before you hit to hard?
  7. #7
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    4,785
    Freeze spray is a good thing to use. The surfaces you are trying to separate are not rusted together. The surfaces are tapered. The puller puts pressure on the parts and the shock of a hammer strike will loosen it.
    I would not swing the hammer as if you were breaking large rocks into small rocks, but, hit the center of the puller hard. After you strike it see if you can tighten it some more. Repeat.
    Chris
    Jersey Shore.
  8. #8
    Join Date
    Sep 2006
    Location
    Baton rouge, La, USA
    Posts
    2,501
    if all else fails and you tried haffimans procedure then just let it set a day or so with pressure on it....add a little more oil a couple of times...it may penetrate and just pop off the next time you try...
  9. #9
    Join Date
    Jun 2011
    Location
    Ontario Canada
    Posts
    107
    I am pleased to report that the flywheel is off. In one piece. It took 48 hours. ATF, heat, freeze spray, 2 pound hammer and 3 grade 8 puller bolts. It sat under tension for most of the 48 hours. It let go all on its own.
    I refer to this as the Dockside Haffiman-Kimcrbr procedure.
    Thank you to all respondents.
Similar Threads
  1. Pulling a stuck flywheel
    By MrRodeoCC in forum Johnson Evinrude Outboard Forum
    Last Post: 05-08-2015, 12:24 AM
  2. Johnson 175 Is it starter bendix or flywheel stuck
    By captainsharon in forum Johnson Evinrude Outboard Archive
    Last Post: 05-04-2008, 11:38 AM
  3. Flywheel stuck on Force 85hp
    By norm_trenaman in forum Mercury Mariner Outboard Archive
    Last Post: 03-04-2008, 07:54 PM
  4. 70 hp Starter Pinion Gear Stuck on Flywheel
    By stren in forum Johnson Evinrude Outboard Archive
    Last Post: 05-10-2007, 09:16 PM
  5. Partially stuck Flywheel JW 10
    By stimpson in forum Archive 2003-2009
    Last Post: 03-25-2004, 07:10 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
