If you are talking about the two seals (set against each other) directly under the water pump plate, but above the base (kinda cone around the shaft), then the answer is yes (but not according the service manual).
The seals can be picked out, with a bit of care, if you take your time (don't slip with a screwdriver and score up the case - a seal (picker) is alot safer).
I have reseated the new seals using a socket (slipped over the driveshaft - drive shaft slips through the hole where the handle would go on a 3/4" drive socket) that's big enough to catch the outer edge of the seals, but still small enough to fit down in the (race) and then putting as even pressure as possible to press the seals in straight.
