Results 1 to 4 of 4
  1. #1
    Join Date
    Feb 2013
    Location
    nola
    Posts
    2
    Default Cat 3208 serial numbers
    I am looking for the serial numbers on two cat motors that don't have the id tags. are they stamped on the block. One is a 3208t 320 hp and i have another with the aftercooler that is 375 hp. Thanks
    38 X 16 lafitte Skiff
  2. #2
    Join Date
    May 2007
    Location
    Kawarthas
    Posts
    3,224
    Default Re: Cat 3208 serial numbers
    every Cat block has the serial numbers stamped in the block. Usually left rear just below cylinder head.
    Factory Manual Best, Seloc 2nd best, Clymer if you're desperate.
  3. #3
    Join Date
    Feb 2013
    Location
    nola
    Posts
    2
    I found out that if it is a Remanufactured block who ever built it is supose to stamp the number on the block.
  4. #4
    Join Date
    May 2007
    Location
    Kawarthas
    Posts
    3,224
    the serial number doesn't change when an engine is rebuilt
Similar Threads
  1. Serial Numbers??
    By bowhuntAZ in forum Identifying Model / Year / Horsepower
    Last Post: 04-26-2011, 05:16 PM
  2. Replies: 0
    Last Post: 04-08-2011, 09:28 PM
  3. Strange Model Numbers and Serial numbers on pcm motor cant find year or hp
    By castin318 in forum Pleasurecraft Marine PCM Forum
    Last Post: 03-21-2010, 06:07 PM
  4. Serial Numbers
    By sam_wilson in forum Detroit Diesel
    Last Post: 08-11-2008, 03:50 PM
  5. Serial Numbers
    By littld62 in forum Mercury Mariner Outboard Archive
    Last Post: 04-13-2006, 01:34 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
