Sailingbum
Hi I was just suckered into a 2006 3.5b tahatsu thinking it had a bad impeller ( owner bought the engine new and said he never even noticed any water flow).Anyhow I pulled apart the lower unit and the impeller was fine and a double threaded support blt was missing according to the parts layout.
I ran water from a hose up through the intake but their was only a spittle from what I assme is the steam sensor(back side of lower unit about the middle) which seemed to put out some exausts when running. I pulled apart the therma stat and it was caked with salt and didn;t seem to work until I boiled it a bit. then it was OK. I the tried to run waterer in at the thermastate housing and I got good flow fro the prp and all seemed like it may be OK so I refilled the oil which had clouded a litle during this process and started her up. Water milked up the oil.
Now I am attempting to remve the powerhead so I can clean ut the water jacket and hpfully find a blwm gasket some where casing thi water leakage So what I need to know is:
1. does the pwer head come ff by justs remving the munting screws n the underside because it des nt want to move ?
2 Is there a gasket that i may have blwn with the hose forced water pressure like something simular to a head gasket(I can't find one in the parts layout just a valve cover gasket)?
and
3. any recommendatins for product that deslve cake n salt?
Or any other words f wisdm fr the collective of minds.
Thanks, Rick
and
Thanks, Rick
