Will, my apologies for the disruption by Tahoerover. Some people would rather stir the pot, than to actually offer help.
(notice that he passed on my challenge.)
.......... what would be involved in putting a standard rotation engine in place of my reverse rotation on the STBD side? I have a paragon V drive. A guy at the marina told me to just flip the pump. Would I still need a new prop?
Will, I believe that your question left this somewhat open to interpretation..... at least on my behalf, but I may have misunderstood you.
I made the assumption that you wanted to maintain the same Stbd side CW propeller rotation by reversing the transmission output direction from that of a standard LH engine.
The transmission that I believe you were hoping for, would have not only been
reverse input/output rotation capable, but also capable of
"opposite to engine rotation", such as the Masson Marine transmission and some of the V-drive transmissions (for example).
This type of transmission solves your issue.
Will, let's recap this, and see if I'm understanding you.
Port side existing:
Standard LH rotation engine turning CCW when viewed from the flywheel.
Prop is also turning CCW while viewed facing the stern.
Rubber is offset for CCW propeller.
Sea water pump is correct for this rotation as well as the transmission oil pump.
Stbd side existing:
Reverse RH rotation engine turning CW when viewed from the flywheel.
Prop is also turning CW while viewed facing the stern.
Rubber is offset for CW propeller.
Proposal:
You'd like to build up a spare Std LH rotation engine that could be used for the Stbd side (if need be), if the transmission is
"oposite of engine rotation" capable.
Isn't this the actual question?
Or are you willing to swing a LH (CCW) prop on the Stbd side, and deal with the offset rudder?
We know that the transmission oil pump can be reversed for either LH or RH engine rotation.
We know that the sea water pump can be reversed.
However, the Paragon information lists the PV 300 as
not being
This would mean that a Standard LH engine (installed in the Stbd side), would need to turn a CCW direction propeller.... (same as Port side).
If your Stbd side rudder is offset to accommodate a CW propeller rotation, a Stbd side CCW propeller may be problematic for you.
Add to this that both props would now turn CCW, so there may be a concern as to what and how would this affect hull performance, low speed docking, etc?
Unless I'm clear out in left field here....., to do what you propose, you'd need a transmission that is
If the PV 300 transmission will not work for this, I still think that your best bet would be to have all of the new "spare" engine components ready to go, but not yet assembled. Then you'd build this engine in either a RH or a LH version, as required at the time.
Does that make sense?
