Hello everybody,
There is something weird happening with my DV20 which I cannot understand. In fact, my engine starts properly as always done but after about 10 minutes of normal functioning it just stops. You can see that the oil pressure falls from 2 to 1 and the engine goes silent. Sometimes I also get some smoke from the injectors area and it seems to hear also a metallic sound (as if some little stones were bouncing inside of the engine head).
What I have done to try to solve the problem (whatever the cause might be):
1) removed the diesel from the tank
2) cleaned the tank
3) put new diesel in it + additive for injectors
4) changed the filters
5) put new injectors
6) changed oil
Result: no change at all.
A local mechanic came over but he had no solutions to propose. Do you have any idea which might help solving the situation?
