AD41B Fuel pump leak
Hi
I have a fuel leak , having removed the shut off spring the fuel can be seen dripping from the shout off solenoid shaft at the top of the pump .
I am hoping that the top of the pump containing the stop solenoid (seals etc) can be serviced without removing the pump from the engine ?
Any advise would be appreciated - Thank you
Hi Glen,
Thank you for your response .
The leak is dripping from the manual shut off shaft. The solenoid is a little lower on the pump. I am hoping to be able to dismantle the top of the pump whilst on the engine. I have two VP AD 41 B's , the fuel pump on the other engine was leaking last year but from the casing , this had to be removed & dismantled.
Any advise appreciated .
Kind regards
Colin
