I have a 2011 Nissan 6hp with a 7.8x7 prop.
The 6hp Nissan is mainly used while trolling on my 17' Maxum with a 120hp Force main outboard engine.
My boat is quite heavy so of course the 6hp is not strong enough to get the boat up on plane.
I have on occasion had to return to the ramp using the 6hp Nissan when I have had problems with the main outboard not starting.
Will changing the prop to a 7.8x8 size give me more speed than the current 7.8x7 prop should I have to use the 6hp if the main engine will not start or does the added thrust from the 7.8x7 result in the best non-planning speed?
How will changing the prop to the 7.8x8 size affect the trolling performance?
Thanks for your advice.
Michael
Michael
