Hi all,
I have a Yamaha 150 2 stroke. For the past few months the engine would bog down when run at high rpm's. I figured the carbs needed to be cleaned, but just never got around to it. I tried to start it a couple days ago and nothing. I get it to turn over but only after I've choked it a few times and have the throttle down about half way. It will run rough for a bit then slowly die. I took the carbs off, cleaned (were not bad ) and rebuilt with new gaskets. I changed the battery, checked the spark plugs. The primer ball gets nice a tight. I took the fuel filter off and found a small amount of water. I do not have a water separator, but the amount of water was very small and have never had a problem with it before. I tried to start it on a remote gas tank thinking the problem could be with the boats gas tank, but got the same results. I'm all out of ideas, any help would be greatly appreciated, thanks.
