Results 1 to 6 of 6
  1. #1
    Join Date
    Apr 2011
    Location
    Chesapeake VA
    Posts
    28
    Default what size prop do I need 1972 50 hp Johnson
    Im running a 12 3/4" x 21 prop on a 50 HP Johnson I have this on a 16' simmons sea skiff. It revs up in neutral but wont rev up in gear. This motor
    runs great until I put it in gear. It seems like ist moving kinda fast at idle. But not sure what els to look for ?
  2. #2
    Join Date
    Dec 2009
    Location
    Pickering and Lakefield, Ontario, Canada
    Posts
    748
    Default Re: what size prop do I need 1972 50 hp Johnson
    Is the problem something new? Did the boat and motor combination work ok before?
  3. #3
    Join Date
    Apr 2011
    Location
    Chesapeake VA
    Posts
    28
    No Bill I just put this motor on this boat and I have only run this motor in a drum.
  4. #4
    Join Date
    Dec 2009
    Location
    Posts
    748
    If the motor is running ok, I'd say your prop has way too much pitch. I run the same motor with a 17" pitch prop on a 15 foot f/g boat. Runs about 30 mph, turning 5,000 rpm. I tried a 21" pitch, just because I had one. The boat wouldn't even plane out.
  5. #5
    Join Date
    Apr 2011
    Location
    Chesapeake VA
    Posts
    28
    Thanks Bill I will try a 17" I'll post the outcome. Thanks again.
  6. #6
    Join Date
    Dec 2009
    Location
    Posts
    748
    Yeah, let me know if that works.
Similar Threads
  1. johnson 2001 90 hp ocean pro prop size
    By grossmb1 in forum Propeller Selection and Replacement
    Last Post: 02-22-2011, 04:23 PM
  2. Engine's RPM range prop size 1972 70hp
    By mac_55 in forum Chrysler Force Outboard Forum
    Last Post: 07-03-2010, 10:22 AM
  3. 82 johnson 60 prop size
    By cfreebird350 in forum Johnson Evinrude Outboard Archive
    Last Post: 08-14-2007, 06:38 PM
  4. Prop size for a Johnson V4 75 HP
    By ko4nrbs in forum Johnson Evinrude Outboard Archive
    Last Post: 08-08-2006, 06:32 PM
  5. 1990 Johnson 40 HP Prop Size
    By Larkin M. Buechmann in forum Outboard motors archive 2000-2004
    Last Post: 08-16-2002, 09:28 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
