MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 5 of 5
  1. #1
    Default mariner 150 hp dies at high speed
    dears
    I have 150 hp mariner it runs good at low speed but it will die at high speed, carb has just been rebuilt and new spark plug .
    Please help.
    regards
    sayed
  2. #2
    Join Date
    Sep 2010
    Location
    louisiana
    Posts
    76
    Default Re: mariner 150 hp dies at high speed
    First thought that comes to mind is something is causing no fuel to your motor.... Did you check for a collapsed bulb, is the tank vent clear, is your filter new? You may have some crud on the dip tube in your tank. Might be this ethanol stuff has ruined the inside of you fuel lines. Hope this helps...BF
  3. #3
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    I agree w/BF...Get someone to ride in the back and squeeze the ball when it starts to sputter. If it keeps running the fuel pump may have a small hole in the diaphragm and can't keep up with the fuel demand.
    Fix minor things (replace wear items for preventative maintenance.) that cause major problems before they break.
  4. #4
    Dears
    I oppened the engine and found one piston damaged what could be the cause.
    best regards to all.
  5. #5
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    A lack of lubrication or detonation. Post some pictures.
Similar Threads
  1. 1986 Mariner 75 hp 4 Cylinder dies at low speed around 1000 rpm HELP
    By 86fisher in forum Mercury Mariner Outboard Forum
    Last Post: 04-19-2011, 08:24 PM
  2. Mariner 30 dies above idle speed
    By edells in forum Mercury Mariner Outboard Archive
    Last Post: 06-09-2009, 09:54 PM
  3. 2000 Yamaha V6 0x66 Ocean series II Dies at high speed
    By seandrabek in forum Yamaha Outboard Archive
    Last Post: 12-08-2008, 11:00 PM
  4. 37L Mercruiser Dies at High speed
    By Tom Boshar in forum Mercruiser Sterndrive Archive
    Last Post: 07-12-2006, 10:26 PM
  5. 98 hp Mariner Cuts out at Mid amp High Speed
    By 76merc110 in forum Mercury Mariner Outboard Archive
    Last Post: 04-20-2006, 09:09 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
