My 2011 4hp 4stroke Nissan (NSF4C) will not always shift into forward or reverse gear.
I can normally shift from neutral to forward and back into neutral but not into reverse. If I rotate the prop about 1/2 turn while in neutral it will shift smoothly between all the gears. This is the case when the engine is running or not. This has been a problem since the engine was new.
The engine runs fine at all throttle speeds when in neutral or when in gear. When changing the gear case oil there are no metal filings and no water in the oil.
Is it possible this problem can be resolved by a linkage adjustment or is the problem likely in the lower gear case?
Is there a repair manual available for this model engine?
I appreciate any suggestions on how to fix the problem.
Thanks for your assistance.
Michael
Michael
