Are you shure Malibu uses a 383 in there boats?
I was not aware that OEM/GM released a 383 production motor pre LS motor.
To my knowledge, GM did not. The LS3 6.2L version was for the Corvette I believe.
That is where Merc would get it from and malibu would simply install it.
GM does produce a "stroker" for Merc's Horizon 6.2L, of which is a 377 cu. in. (standard 4.000" bore)
The 383 cu. in. version (6.3L) would be a remanufactured, in that the bore now becomes first over (4.030").
If it is a LS motor then that is a different animal all together.
I know gM released a 383 but have never heard of it going into a boat as a stock marine engine.
That would be Merc's Horizon 6.2L or 377 cu. in.
Once again.... keep in mind that GM used their full dished pistons in these.
Look at the specs here and here.
This is another example of how all of the components are mentioned, with exception to the piston profile.
When a certain good feature is absent from the specs (in lieu of a lessor feature), no one is going to capitalize on it.
However, when a certain good feature is used, you can bet that they're going to capitalize on it.
I will give them credit for listing a more honest horse power rating.
The bottom line is, what ever you choose to do, if you biuld your own, get with a engine biulder and put a parts combo plan together that siuts your needs.
Yes.... ditto that one!
High tourque at low rpms........STart there and then adjust the rest of the components for good power.
Most boats rarely go past 5000 rpms so keep that in mind.
Hence the reason for the shorter connecting rods and longer piston skirts.... AND the tighter quench dimension.
$3500 is a healthy price and I would suspect it is for a new motor and not a rebiult one.
Also understand that with todays parts availability making a standard 350 cubic inch motor a tourque monster is not that difficult.
Not quite as torque'y as it's cousin the 377/383 with the .270" longer stroke, but with a good quench, you can gain some torque.
Anything to bring LPCP closer to where it needs to be.
Good heads, cam, pistons and as stated get the piston profile, quench and valves correct and you will have a motor of good power where and when you needed it with very high reliability.
Fully agree.
