Just recently bought a 1971 Mercury Comet 7.5hp to use as a kicker motor. Wasn't getting spark to the No. 1 plug so I had to replace the bad wiring coming from the points. Getting spark to No.2 plug. I swapped the wire coming from the No.1 points to the No.2 coil and get spark. I removed the green jumper wire from between both coils, it was frayed, insulation falling off, etc...Made up a new jumper wire with 12 gauge wire, still no spark at No.1 plug. But if I remove the green wire coming from the stator to the No.2 coil and hook it up to the No.1 coil, I get spark at the No.1 plug. So this tells me the coils are good, am getting juice from the points and getting juice from the stator. Why is it when I hook up the jumper wire between the two coils I can't get fire to the No.1 plug? Is it possible the new jumper at 12 gauge is too much and maybe I should go to a smaller gauge? I used this gauge wire to replace wires coming from the points also as I couldn't find anywhere as to what gauge to use.
