I don't know of any prop shops what will work on a small prop hub like that. They likely can't get the hub in the first place. Plus, a new prop costs about the same as a repair (again due to the size). If replacing the prop, determine whether you want the same pitch, or would prefer something else. Exactly what kind of boat is it on? MSRP on the 3-blade props is $62.23. The HT 4-blade props are $73.15, and are a good choice for a heavy rig. We use the 5-pitch 4-blade HT prop on our HR-28 sailboat (over 7,000 pounds), and achieve perfect 6,000 rpm WOT (for the NSF9.8A3). You will want to get to between 5 and 6,000 RPM at WOT for an NS9.8B, so if your boat pushes much more easily, the 7-pitch 4-blade HT prop is probably the best choice.
