Fish-a-Palooza
I know some of you have done the 3.0 to 4.3 swap so I was wondering if anyone with a capri or a trophy can help me out by giving me some info on how tall you made your new mount towers?
FYI and FWIW, two of my twin engine OEM engine mount towers sit off to the sides of each stringer and two are more or less sandwiched to the stringers............ so building anything "up" with plywood would not have worked (cannot build off my bilge floor, it isn't designed to support the engine). Building sideways with plywood off existing stringers and then setting a 600 pound engine on it - no thanks.
Ayuh,... Disagree all ya want,... You asked How it's done, 'n have been told....
Yer askin' for 3 dimensional dimensions, with no available center axis to measure from...
I've only done this, oh, 'bout a dozen times, 'n measurin' where it came outa, Don't help with where it's goin' too...
I don't believe that's what he's suggesting, Wayne.You’re telling me that all boat manufacturers drop the motor in every boat, line it up and measure before they build the mount towers?
RicardoMarine aka 2850Bounty, That's NOT your pic !!!. :rolleyes:
Here's what I think Bill is suggesting regarding this and a center axis;
Install the inner/outer transom unit, set the engine in on a "dry run" basis leaving it hang.
Use the alignment tool to gain your correct center axis (aka engine drive coupler alignment).
Set the engine mount stud nuts near the center of their adjustment range.
Now take your measurements from the side engine mount bottoms to the stringer tops.
Pull the engine back out of your way, and build the new towers to accommodate this elevation.
Well I don't know what happened to my post, it was here the last time I logged in. Either the 70's were harder on me than I thought or it was deleted? I would have assumed I would have received a PM is that was the case so, I'll try this again.
The answer to building the mount towers, at least for me was 2 inches. I dropped the motor in and it was obviously tipped down in front. I lifted the motor, stuck 2x4's under each mount and all was good. Your mileage may vary depending on the type of engine mounts you're using.
So two things here;
One: my hope was Bayliner would have built the boat so it would accomodate either motor it came with, the 3.0L or the 5.0L. Obviously they did not, and some modification to the stringers is necessary for the bigger engine.
Two: I went back and re-read my responses and some of them were a liitle crass. Sorry to Bondo if I offended you. In the end you were correct.
Ayuh,.... I liked yer update much better, before ya deleted the Apology,....
