TonyJ1961
Tahoe,
You sound like my Piston Engine instructor from college. He was acrew chief for C-130's and knew his way around C-97's, C-124's, B-36's (six-a-turnin' and 4-a-burnin') and just about every round piston engine built.
You are speaking my language brother!
So which Glenwood log and riser combination did you use? Did you need to mill the ports on the log?
Did you use aluminum or cast iron heads? What did your guy use for port matching?
I'll be running a Velvet Drive. It has a cooler inline. Is there a way to boost the pressure? A spring swap or a twist of an adjustment screw?
Tony
Tony
