Having both worked on a OMC 351 EFI system and adapded a street system to a marine 351 the major diferance I found was the fuel delivery on the marien system dose not have a return to the tank. Also all the fuel lines are stainless after the fuel pump.
I believe that the fuel return line is one of the issues here. I'd think that the pressure lines could be dealt with.
I spent a lot of time trying to determain just how the power curve difered from the automotive system and the OMC set up and was not able to find anything specific.
You should be able to find the curves if you look deeply enough.
Just do a generic ingition advance curve graph search. I've seen these quite often when searching for Marine curves, but have never paid any attention to them.
What I did find was total advance data to rpm. With EFI this curve is controled by RPM/manifold vacuum/ and the knock sencer.
Basicly the controler figures it out and ajusts timing and mixture to the load. It dosn't mater if its in a truck a car or a boat.
Again, I think that if you were to compare the two, you'd see quite a difference.
It's all about LPCP and how we get there, yet avoiding Marine Load Detonation potential with the Marine Engine ignition advance.
HP automotive engines typically pass through the RPM range where Detonation potential may be greatest, whereas with Marine Loads in a cruiser style boat, we tend to remain at/near these RPM ranges for sustained periods.
Detonation can be self perpetuating. A cylinder detonates, and the cylinder temperature increases. As cylinder temperatures increases, detonation becomes exaggerated, and it self perpetuates, and so on.
As you know, the damage can be anywhere from mild to ugly..... and it can cause severe damage in a split second given the right conditions.
The ECU, EEC, or whatever controller is used, along with knock sensor influence, etc, apparently does cut back advance when needed. However, (and I don't know the answer to this myself) how many samplings will the controller require before establishing a consistent advance curve and correct fuel metering?
Trust me I was very hesatent to make the invesment of time and $ and all your concerns regarding marine verse street and there are a few i.e. the fuel delivery. Like Rick points out safty is formost. As to the control system its a lot more giving than you think.
Well, my point went a bit furture than just safety alone. Engine safety would be included, IMO.
Nixes mate
