FionaBowman
Hi all
I have a Volvo MD2010 with a control panel with 4 lights (temp, oil, alternator and glowplug).
Normally when starting I turn the key to position I and the 3 warning lights (temp, oil and alternator light up. Then I turn the key against the spring to II and the Glow plug light comes on as well for 10 secs or so followed by an audible alarm at which point I turn the key to III to start.
Now however at position I the Temp light does not come on - only the oil and alternator.
Then when I turn to II the oil and alternator lights go out but the glow plug light does not come on (so no lights at all). There is an audible 'click' from the engine at this point (relay?).
The audible alarm does not sound (alarm test button does not sound either) but if I continue to II the engine turns over as normal.
I have swapped the warning light bulbs over to test and all bulbs are functioning.
Any suggestions are welcome as I have no idea what the problem is!
Thanks!
Thanks!
