Hello... I have the same problem on one of my DP A drives. I have replaced both sensors due to other reasons and this did not fix the problem of creep on one drive. It is visually creeping up, both undeway or stationary at dock, very very slowly either running or with engines off. You would never be able to hear the pumps over the noise of the diesels, and it happens when all power is off, so I can say it is not the pumps going on. Out on the hard when in winter storage it is a measureable couple of inches of creep up. I too would be interested in suggestions as this is something that is a constant over 5 years. I thought maybe air, so I tried full up & down a few times to work any air out. Also changed out the fluid in both drives and cleaned out the reservoirs and added fresh transmission fluid per the manual, not hydraulic oil, just incase there was contamination..... so what do I try next??
