yamaha f 25 2007 crankshaft
thrill
I own Yamaha f 25 year 2007 europian model. The crankshaft is dameged -0.02 mm. my question is: is there appropiate plane bearing, or i have to buy new crankshaft, also, is the crankshaft for usa models is the same for europian models? ( sorry for my poor english)
my crankshaft is dameged 0,02 mm, and i dont know which color of crankshaft plane bearing i need. I dont know the dimensions of plane bearing
ok. thank You, what I want to know the dimensions of the bearings, or thickness of bearings, or the color worn bearings that dimension, as well as whether the crankshaft for the American and European models of the same
If it is damaged then you need to get it ground undersize if the bearings are available. Buy a new one if not or have yours welded, ground, and checked for straightness and put back to specs, if possible. I didn't see any reference as to if you fixed the damage or not.
