Spraying fogging oil into the cylinders via the spark plug ports is not fogging, IMO. Well, let me clarify that.....
at least not in my book!
IMO, that is more in line with what I'd call a weak form of "Pickling", and it really isn't even pickling!
Fogging is done dynamically, not statically.
Since the V engine cylinders are not perpendicular (vertical), any oil sprayed into the cylinder will have a tendency to pool at the low side of the piston ring landings. When you turn it over, only the lower side of the cylinder walls will be wiped with oil.
Add any piston negative dish volume, and this becomes even less effective.
Quite frankly, this method does little to protect valves and/or valve stems as well.
If you want to actually Fog this engine, do it while running it (i.e., dynamically) at approximately 1,200 rpm.
You can properly Fog an engine in about 10 seconds of run time.
Have a helper hold engine speed while you Fog.
Ask the helper to cut the Ignition while you continue Fogging (no change to throttle opening) until the rotating mass comes to rest.
This way combustion is not burning the last bit of the fogging solution.
If you want to gain a more ultimate method of fogging, pull your sea water pump impeller, and do this while operating minus sea water.
We're talking about a 10 second dry start only.
This additionally blows any residual water from your exhaust system.
I've been using this method for longer than I can remember...... and with no issues what-so-ever, to date.
The 4.3L also uses a dual plane intake manifold. This means that an equal amount of fogging solution must be sprayed into each plane (i.e., each primary throttle bore).
If we miss one plane, we may also miss 3 cylinders.
In my book, that's Fogging.
Sorry... can't help you on the spark plug removal!
Thanks for the help appreciate it. I normally just use fogging oil when the engine is running and keep spraying it until the engine quits. However, this year i planned on changing the plugs anyway so i thought i might give each cylinder a good squirt or two. I bought the boat new in 2008 and those are still the original plugs. Anyway im kind of a maintenance nut, i enjoy that kind of work.
