I'm having problems again with my honda bf130. I just changed out the low pressure fuel pump a few months ago and the engine was running great, I made a 120 mile run with no problems before this happened. I filled up the tank and stored the boat for about 3 weeks or so, today when I put it in the water and tried to start it, the motor will turn over and run for about 3 seconds consistantly but will not run after that.
The fuel primer bulb is hard
There is no water in the fuel/water external separator
When I pump the bulb when the engine fires up for those three seconds the bulb continues to be hard but even pumping the bulb will not keep the motor running. This is very different than when my low pressure fuel pump went out because then I'd pump it and it would run until I stopped pumping it and then it would die.
When I turn the ignition on it beeps twice and then when I click the key over to the final click the engine starts, again for only three seconds before dying.
I am thinking that it is either the high pressure fuel pump, the main relay or perhaps some fuses? Is there any place I should start looking first? I don't hear the high pressure pump running when I start the engine during those two beeps, is it fairly loud and obvious?
Thanks!
Thanks!
