Hi guys. I'm new on here. Any help would be appreciated.
I just pick up a 1988 Sunbird Eurosport. The engine is a 4.3 L 260 CID V6 OMC Cobra. The boat was basically a gift. I was told the engine leaks water. The previous owner doesn't know where the leak is coming from. He just assumed it was a cracked block. (This is why it was basically a gift) The motor apparently runs but I haven't tried to start it yet because I cant check the oil. The dipstick hole near the starter is plugged and I don't have any information on the last oil service. This is my first I/O boat. Previously I owned an outboard. This leads me to my questions...
1. How do I remove the plug in the oil dipstick hole to check the oil? I want to verify that there is no water in the oil and that there is in fact oil to begin with.
2. Are there common issues or locations for a water leak or cracked block? IE: Freeze plugs, gaskets, water jackets and so on...
3. Do you have any suggestions or advice to go about checking the motor over? I don't know much about the motor or service records.
Any advice would be a great help.
Thank you in advance,
Chris,
Chris,
