MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 5 of 5
  1. #1
    Default 200hp od213741 gas/mix
    od213741 is what year and is gas mix 50/1 or 100/1
  2. #2
    Join Date
    May 2013
    Location
    TX.
    Posts
    264
    Default Re: 200hp od213741 gas/mix
    You can't go wrong with 50. Said to provide better corrosion protection than 100 even if the engine could run on special 100:1 oil. If you use Pennzoil premium it is synthetic blend and smokes very little. I use it and buy from WW. 1 pt of 2 stroke TC-W3 to 6 gal 87 octane gas. Most newer Mercs are designed for 10% max ethanol.
    Mark
  3. #3
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    4,834
    It seams to be a 1993. Is the oil injection system still working?
    Chris
    Dockside Marine Services
    Jersey Shore.
    Mercruiser/Mercury Certified
    Let the insanity begin.
  4. #4
    Join Date
    May 2013
    Location
    TX.
    Posts
    264
    Safest way to find out for sure is to pre-mix your fuel at 50:1 just until you get an answer at least. Go to your oil tank and make a mark at the oil level. Go out and run the engine for awhile and check the level. Your answer will be right in front of you. If the injection system is working it may smoke a little till you burn off the pre-mix, but that's not going to hurt anything. If worried, add a can of Sea Foam to the tank and it will clean up any combustion problems the extra oil MIGHT cause.
    Mark
  5. #5
    Quote Originally Posted by Texasmark View Post
    Mark
    sorry I have not got back with you. The pre-mix has been taken off. So I JUST mix the gas 50/1. motor is running now. I need to put it on the water. thanks for your help.
Similar Threads
  1. 200hp no spark at all
    By peanuts in forum Identifying Model / Year / Horsepower
    Last Post: 10-16-2012, 07:44 PM
  2. 25L 200hp
    By sidebottom in forum Mercury Mariner Outboard Archive
    Last Post: 07-25-2009, 04:10 AM
  3. EFI 150 INTO 200HP
    By eieieiooo in forum Mercury Mariner Outboard Archive
    Last Post: 05-05-2008, 11:48 AM
  4. 25 200hp
    Last Post: 04-21-2008, 02:30 PM
  5. 200HP compatibility PLEASE HELP
    By mavalos in forum Yamaha Outboard Archive
    Last Post: 01-23-2008, 05:33 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
