Results 1 to 4 of 4
    Default Carb adjustment question on Sears 7 hp
    This is the same engine that Mr. Crabs has helped me with. There's a screw on the bottom of the carb (needle adjustment?) that I don't know where it should be.
    Anyone?
    Aug 2010
    Bank of the Ohio river
    138
    Default Re: Carb adjustment question on Sears 7 hp
    some require finger tight adjustment, it all depends...its not much out if that helps
    Quote Originally Posted by MrCrabs View Post
    Thanks for the reply sir. I can get the motor to run but it won't stay running. Seemed like I had it flooded today... pumped a lot of gas/oil mix through it just pulling. Had no spark again so I tightened up the air gap and got spark. Seems like a tempermental motor; I can get it running sometimes but not reliably. Seems like it's definitely a fuel issue because when it does start, it runs strong.
    Aug 2010
    138
    sounds like the ignition is not synced right to the carb, you should have the stator cam move just a tad before the butterfly opens, this a must tune situation everytime you mess with the ignition and carb,
    I can give you more detail but you really need the engine carb manual, e-mail me [email protected]
  1. 50 Hp Merc/Mariner Walbro Carb Float Adjustment/ Rebuild Question
    By ehlien in forum Mercury Mariner Outboard Forum
    Last Post: 09-18-2012, 02:41 PM
  2. Replies: 2
    Last Post: 07-19-2011, 10:05 AM
  3. sears 3.5 carburator adjustment
    By cwadams in forum Gale Outboards
    Last Post: 07-05-2010, 10:03 PM
  4. sears carburator adjustment
    By cwadams in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 06-10-2010, 12:24 PM
  5. 1973 Evinrude 65 Carb adjustment Dumb question
    By c22narf in forum Johnson Evinrude Outboard Archive
    Last Post: 08-05-2008, 12:00 AM
