Results 1 to 4 of 4
  1. #1
    Default Carb adjustment question on Sears 7 hp
    This is the same engine that Mr. Crabs has helped me with. There's a screw on the bottom of the carb (needle adjustment?) that I don't know where it should be.
    Anyone?
  2. #2
    Join Date
    Aug 2010
    Location
    Bank of the Ohio river
    Posts
    138
    Default Re: Carb adjustment question on Sears 7 hp
    some require finger tight adjustment, it all depends...its not much out if that helps
  3. #3
    Quote Originally Posted by MrCrabs View Post
    Thanks for the reply sir. I can get the motor to run but it won't stay running. Seemed like I had it flooded today... pumped a lot of gas/oil mix through it just pulling. Had no spark again so I tightened up the air gap and got spark. Seems like a tempermental motor; I can get it running sometimes but not reliably. Seems like it's definitely a fuel issue because when it does start, it runs strong.
  4. #4
    Join Date
    Aug 2010
    Location
    Posts
    138
    sounds like the ignition is not synced right to the carb, you should have the stator cam move just a tad before the butterfly opens, this a must tune situation everytime you mess with the ignition and carb,
    I can give you more detail but you really need the engine carb manual, e-mail me [email protected]
Similar Threads
  1. 50 Hp Merc/Mariner Walbro Carb Float Adjustment/ Rebuild Question
    By ehlien in forum Mercury Mariner Outboard Forum
    Last Post: 09-18-2012, 01:41 PM
  2. Replies: 2
    Last Post: 07-19-2011, 09:05 AM
  3. sears 3.5 carburator adjustment
    By cwadams in forum Gale Outboards
    Last Post: 07-05-2010, 09:03 PM
  4. sears carburator adjustment
    By cwadams in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 06-10-2010, 11:24 AM
  5. 1973 Evinrude 65 Carb adjustment Dumb question
    By c22narf in forum Johnson Evinrude Outboard Archive
    Last Post: 08-04-2008, 11:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
