change over from motor guide to minn kota
kdill
I want to change from a motor guide to a minn kota. Will simply changing the plug connection be all that is required and if so is it an easy swap out.
Assuming voltages are the same, just switch the plugs and go. Might even be easier to put whatever plug is on your MG on to the wires from the new MK, that way you don't have to mod the boat at all.
