This is the symptoms:
- The PTT motor is running, but it doesn't raise or lower the motor
- The motor will sink to lowest position if let by itself
- I can manually rise (hard in low position) and lower it manually. No difference if manual release valve is open or not.
- When moving it manually, it has a slack with no hydraulic resistance at all.
- There is no leakage if fluid.
This is the history:
All funcioning well, but suddenly the trim motor didn't respond. So I startet troublewshooting, and opened the manual realease valve. As a newbe, in that operation I removed the secure ring and opened the valve so much that a little fluid ran out. Closed it immediatly. However, it showd up to be the battery that was malfunctioning, even though it had 12.4 V. But with a new battery, the PTT now has the symptoms as described above.
I am thinking whether some of the valves might be the problem? I hav no understanding of the internal mecanism, so if somebody can explain how the fluid and valves are funcioning (or can link to a description) it might help me on the way
