Click for Nissan Tohatsu Manuals, and Parts!
Results 1 to 7 of 7
Thread: 25hp conversion
  1. #1
    Question 25hp conversion
    I have a 2004 M25C3 tohatsu 2 stroke outboard. It is a pull start. Due to shoulder issues, i'm thinking of converting to an electric start. What is the bare minimum I need to make the change. I have a battery on board that can be charged after each outing so a charging circuit isn't absolutely necessary, though would be nice. What would this cost, and can i do it myself. mechanically inclined. Thanks
  2. #2
    Join Date
    Mar 2010
    Location
    Buffalo, NY, USA
    Posts
    2,094
    Default Re: 25hp conversion
    You can install
    3P0763000M, ELECTRIC START KIT F TYPE, $608.16
    398760830M, ACTUATOR, NEUTRAL SWITCH, $7.84
    346760820M, PLATE, NEUTRAL SWITCH, $3.61
    Available from any dealer, including me. Prices are MSRP; take 15% off.
    Paul
    Buffalo NY USA
  3. #3
    Join Date
    Mar 2010
    Location
    Buffalo, NY, USA
    Posts
    2,094
    Quote Originally Posted by pvanv View Post
    You can install
    (the kit includes the rectifier, so you can re-charge your battery while running.)
    Paul
    Buffalo NY USA
  4. #4
    Question Re: 25hp conversion
    i tried looking up the part 3p0763000m to see what the kit contained and it said it was unavailable. is it available and what does the kit consist of. thanks
  5. #5
    Join Date
    Mar 2010
    Location
    Buffalo, NY, USA
    Posts
    2,094
    The kit is available from any Tohatsu/Nissan dealer (including me).
    It includes everything to do the conversion just as it would have been from the Factory if you had gotten the EF (electric start/tiller) motor originally. Some bits are qty 2 or 3 as needed:
    346760100M STARTER MOTOR
    9161E30835M BOLT
    9301030800M NUT
    9413030800M SPRING WASHER
    346760400M STARTER SOLENOID
    346760431M BRACKET A, STARTER SOLENOID
    9101030616M BOLT
    9301030600M NUT
    9413030600M SPRING WASHER
    3G2760600M RECTIFIER
    9215030525M SCREW
    9301030500M NUT
    9413030500M SPRING WASHER
    353062810M HOLDER
    353062830M COLLAR
    9101030620M BOLT
    309069720M CLAMP
    9301030600M NUT
    346760810M BRACKET
    9104036508M BOLT
    361760800M NEUTRAL SWITCH
    3M4760840M SPACER, NEUTRAL SWITCH
    346760820M PLATE, NEUTRAL SWITCH
    3B7637310M WASHER
    9109036616M BOLT
    3B2760620M FUSE WIRE
    3V1761202M BATTERY CABLE +/- (NEW STYLE), 8.2 FT.
    3B7761450M TERMINAL CAP, SOLENOID SWITCH
    334761410M STARTER CORD
    9101030612M BOLT
    3B2761471M STARTER CABLE
    3A3761450M CAP BATTERY CORD
    336760910M BAND
    361760260M MAIN SWITCH
    346760070M RUBBER, STARTER MOTOR
    3G2761420M EARTH CORD
    Paul
    Buffalo NY USA
  6. #6
    Paul, is the conversion something a mechanically inclined, non motor repair technecian can do? I have the repair manual, but are there other things i need to know before a start this 25hp conversion?
  7. #7
    Join Date
    Mar 2010
    Location
    Buffalo, NY, USA
    Posts
    2,094
    Yes, it can be done by anyone with average-to-above-average mechanical ability, equipped with a decent set of tools, and the Factory service manual (skip the aftermarket books). It does take a significant amount of time to do the conversion, and requires diligence and patience while working on the motor. There are a lot of small parts, so it's best to study the service manual for a while (to see the differences between electric and rope-only models) before beginning.
    Paul
    Buffalo NY USA
Similar Threads
  1. 2010 e-Tec 25HP tiller to remote conversion
    By nnyerges in forum Johnson Evinrude Outboard Forum
    Last Post: 10-06-2012, 04:53 PM
  2. '99 25HP conversion to 30HP??
    By matt61076 in forum Mercury Mariner Outboard Forum
    Last Post: 06-28-2012, 07:41 AM
  3. Mercury 25HP XD Manual to electric conversion
    By fosterbeer in forum Mercury Mariner Outboard Archive
    Last Post: 03-21-2008, 09:30 PM
  4. 2001 25hp tiller conversion
    By mike broshears in forum Nissan Tohatsu Outboard Archive
    Last Post: 02-28-2007, 09:28 PM
  5. Power Conversion for b90 25hp Johnson
    By Charlie M. in forum Outboard motors archive 2000-2004
    Last Post: 02-27-2003, 11:04 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
