i will try to make this short. temp sender for gauge. i see the replacement one ask one station or two? ihave a 1976 silverton two station. if only one station is being used other station ing is off why do you need atwo station sender or dont you . my crusaders where replaced with new chev 350s. carbs alt sea pumps are no longer crusader stuff.but the wireing i believe is still the same. i have one wire going to each temp sender. gauges on both stations work fine when useing one station at a time. iwas told when i bought the boat if you are in upper station doen stairs station should be off and vise versa. i guess what im asking is how would i know what sender i have?
