MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 7 of 7
  1. #1
    Join Date
    Dec 2006
    Location
    Lake St Clair /Detroit, MI, USA
    Posts
    337
    Default How To Remove The Carbs From a 1883 Mariner/Merc 50 HP 2 Stroke
    Well I was unable to get my Mariner which has been sitting for a few years started presumably because the lower carb is flooding and steaming gas out a small brass port hole shown in the upper right in the front. (not sure what this port is??) I'm assuming the float is not working or a needle not seating properly. Anyway the carb will have to come off. Question is how do I get access to the mounting nuts on the starter side? Do i need to remove the starter if so how do I do that? Attached are pictures of the car and starter.
    Attachment 5504Attachment 5503
  2. #2
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,390
    Default Re: How To Remove The Carbs From a 1883 Mariner/Merc 50 HP 2 Stroke
    Had a bunch of those this summer (ethanol?) You need NEW needles and seats for both carbs.
    Jeff
  3. #3
    Join Date
    Dec 2006
    Location
    Posts
    337
    Appaently they used several differnt carbs on these motors. How do you tell which carb you have and are the needles and seats the same or different for each?
  4. #4
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    There are numbers stamped on the carb. Use the engine serial number to get the parts diagram and search the parts list to match the carb kit.
    Fix minor things (replace wear items for preventative maintenance.) that cause major problems before they break.
  5. #5
    Join Date
    Dec 2006
    Location
    Posts
    337
    good to know ..thanks
  6. #6
    Join Date
    Dec 2006
    Location
    Posts
    337
    Quote Originally Posted by fastjeff View Post
    Jeff
    Well I got the carbs off and so far I have cracked the lower one apart..actually it looks pretty good. No varnish and pretty clean and the gaskets all look in tact. When I originally primed the engine gas was streaming out the economizer jet as indicated in my last post. However now I'm wondering if I just pumped the fuel bulb on the tank to engine line up way too hard?? Would that flood the engine and keep it form starting? ??
    Anyway I cleaned the carb out with cab cleaner and I have a new needle to put in but the marina where I bought the parts said there is no seat available and I don't see one in the walbro parts list for this engine. The float appears to be in tack and not damaged. I sprayed cleaner through the jets and wiped out what I can. What else should I do to service these carbs? Is there a thread or more complete advice on this somewhere else?
    Any help is appreciated getting this engine up and running.
  7. #7
    Join Date
    Dec 2006
    Location
    Posts
    337
    PS no ethanol damage.. from what I can see the seats and the inlet needle and spring look pretty good and clean......did I just over pump the fuel line bulb and flood it?? ..I could get the engine to cough like it wanted to start but never catch..it was actually more like fuel starvation.......
Similar Threads
  1. How to remove carb on old 4hp two-stroke???
    By chatenever in forum Mercury Mariner Outboard Forum
    Last Post: 07-20-2012, 03:57 PM
  2. 1969-70 merc 50hp 2 stroke- how to remove lower unit driveshaft? Please help!!!!
    By Sledhill87 in forum Mercury Mariner Outboard Forum
    Last Post: 06-18-2012, 11:20 AM
  3. Can't remove power head off 1987 40 HP Mariner. Please help.
    By Gene Kimberly Esper in forum Mercury Mariner Outboard Forum
    Last Post: 06-11-2012, 02:25 PM
  4. 2000 Merc 90hp 4 stroke - dry carbs!
    By mtastad in forum Mercury Mariner Outboard Forum
    Last Post: 06-13-2011, 02:04 PM
  5. How to remove old impeller merc 98
    By Jerry B in forum Mercury Mariner Outboard Archive
    Last Post: 08-25-2006, 06:18 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
