Mike Boggs
I need to know the gas oil mix so i can check the oil pump on a pro50yamaha 1987
Typically you would mix one tank at 50:1 and run the motor.-------Check how much oil is injected from the motor oil reservoir after that tank runs empty.------------Motor may smoke a lot but you will not do any damage.
