Results 1 to 8 of 8
  1. #1
    Default have a question i cant seem to get a straight answer on
    can i use a chevy v-8 marine block,crank,and pistons for auto use i have built one and have a vibration in it.Is this because they are internaly balanced and the flywheel has weights on it or what could be my problem?Thanks
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,166
    Default Re: have a question i cant seem to get a straight answer on
    The bottom end of a chevy marine engine will work just fine on dry land...most were spawned from truck applications.
    Regarding the vibration and independent of the auto or marine label, the crank, the balancer, and the flywheel need to be "matched" as to their dynamic balancing approach...a good machine shop should be able to identify what you have and what you need to make it all work.
  3. #3
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,806
    You do not mention which engine you have built..... 5.0L, 5.7L, or a 377/383.
    FYI; the SBC 400 crankshaft harmonic balancer plays a role in balancing the 400 crankshaft.
    I don't know if the 400 balancer will even work on the 5.0L or 5.7L crankshaft......., but if you were to mix/match this balancer with a 5.0L or 5.7L, you may have issues.
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP's
    Please... no PMs! Post your questions on the forum.
  4. #4
    so i need to bring them the motor my balancer and flywheel? correct for them to b matched
  5. #5
    its the 5.7l
  6. #6
    ive tried a smaller one and a larger one i have many parts and im not sure which one is which but with both of them i have the same issue
  7. #7
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,469
    Quote Originally Posted by muddinred View Post
    Ayuh,.... Post some pictures of what ya got to work with,....
    The 350 is an internally balanced motor....
    The flywheel, 'n balancer should have No counter-weights...
  8. #8
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,806
    If you have a machine shop balance the rotating assembly, yes.... they'll need all of the components.
    All pistons and all connecting rods must be within a certain weight of one another in order to correctly balance a rotating assembly.
    Is it possible that you may have one piston or one connecting rod that is not a match?
    Is the deck height equal for each cylinder?
    Is it possible that you have a drive coupler that could be out of balance?
    Any machine shop that does this routinely will know exactly what to do.
    Portland, Oregon
Similar Threads
  1. help me answer Question
    By bigwiggle in forum Miscellaneous marine engine topics
    Last Post: 12-13-2011, 11:05 AM
  2. answer question please
    By j12j27 in forum Johnson Evinrude Outboard Forum
    Last Post: 06-24-2010, 04:01 PM
  3. Question i need an answer to
    By ced in forum OMC Sterndrive and Inboard Archive
    Last Post: 09-05-2008, 06:50 PM
  4. Can someone please help answer this question thank you
    By kitty2818 in forum Archive 2003-2009
    Last Post: 06-03-2008, 05:29 AM
  5. Can someone help answer this question thanks
    By kitty2818 in forum Johnson Evinrude Outboard Archive
    Last Post: 05-26-2008, 08:20 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
