Get instant online access to repair manuals for your Chrysler / Force outboard. Online Manuals
Order printed Chrysler / Force service manuals — shipped to your door! Printed Manuals
Use engine diagrams to find & order parts for your Chrysler / Force engine. Engine Diagrams
Results 1 to 2 of 2
  1. #1
    Join Date
    May 2010
    Silverton ...Near Salem Oregon 97352
    Default 1993 Force 150 hp Outboard ... New in Crate ... Questions
    I have the opertunity to buy a 1993 Force Outboard that is still in its origional crate from the factory for $5000.00 .... Been sitting in a guys garage all this time ....
    I have a couple questions ....
    #1 .... Is $5000.00 to much ... it cost a little under $10,000.00 in 1993
    #2 .... Is it going to have to be gone through by a dealer after sitting so long ??? Or can I just bolt it on and go ?
    #3 .... I am told Force was made by Mercury .... do I take it to a Mercury dealer to be worked on or checked out ????
    Thanks for any help on this ....
  2. #2
    Join Date
    May 2010
    Sebastian ,Fl
    Default Re: 1993 Force 150 hp Outboard ... New in Crate ... Questions
    Yup it's a Mercury product.
    I'd check the pistons for rust and corrosion.
    Do a comp test just for fun.
    Still in the crate??? WOW $5000 I think I'd buy it.
    If you buy I'd run extra oil for 10=15 hrs then go 50-1
    Lube the cylinders before initial start up.
    Everything else should be ok.
    88 Bayliner with 2002 225 HP Mercury EFI
    Buy American made Cars and Trucks!!!Towing insurance for a boat,a GREAT thing.
    ​Tools to make my life easier: Battery tester, die grinder, temp.gun, compression tester, DVA meter.
    In Scenic , Beautiful San Sebastian by the sea Florida
Similar Threads
  1. Crate engine compression problem
    By walldiver7 in forum Mercruiser Sterndrive Forum
    Last Post: 08-08-2011, 09:06 AM
  2. 1993 90hp force outboard engine canbt start
    By cambie10162 in forum Chrysler Force Outboard Forum
    Last Post: 02-16-2010, 03:22 AM
  3. Crate motor
    By dirtydieseldave in forum Volvo Penta Gas Archive
    Last Post: 04-18-2008, 07:18 AM
  4. 1993 Force 90hp Questions
    By tex599 in forum Chrysler Force Outboard Archive
    Last Post: 09-03-2007, 09:56 AM
  5. 1993 40 force outboard replaced rectifier
    By Pat Celli in forum Chrysler Force Outboard Archive
    Last Post: 03-06-2006, 06:04 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
