The motor just quit during operation. Took apart cleaned parts replaced springs,brushes,o-rings and bearing, when put back together still no power. My thought was to check the wire connections under the brush plate after replacing parts but could not figure out how to remove the plate. Now I would like to find out how to remove the plate to check the wires for proper connection under the plate. I see 2, what I call pins, that seem to hold the plate and they seem to be pressed on because the heads are flat. Any help on how to remove would be great, thanks.
